2005 chrslyer 300 lock/unlock motor
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109843
Printed Date: March 28, 2026 at 4:51 PM
Topic: 2005 chrslyer 300 lock/unlock motor
Posted By: bgraper
Subject: 2005 chrslyer 300 lock/unlock motor
Date Posted: December 17, 2008 at 10:41 PM
When installing the remote start, do I need to use the lock/unlock MOTOR wires?
I have installed a 2002 Chrysler Sebring remote start with absolutely no issue. I am fine with resistors and relays.
I am not sure what to do with the lock/unlock motor.
ALSO --> The headlight wires. There is a positive AND a negative. DO i need to use relays to trigger both of these when the remote start sends the headlight signal?
Posted By: ckeeler
Date Posted: December 17, 2008 at 11:16 PM
use only one parklight wire, either negative or positive will work.
the lock/unlock motor wires wont be used at all. unless your going to do driver door priority. those are for the actuator in the door.
