05 silverado remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109862
Printed Date: March 29, 2026 at 7:27 AM
Topic: 05 silverado remote start
Posted By: sinkhole
Subject: 05 silverado remote start
Date Posted: December 18, 2008 at 7:22 PM
Hey all,
Just put a Viper 5101 Remote Start with a XK01 By-Pass Module in my 05 Silverado. Remote Start works fine, door lock works fine, window roll-up works fine, but when I hit un-lock the doors un-lock ok, but the DTR lamps and reverse lamps come on. I can't seem to figure out why this happens Does any one have any clue why this happens?
Thanks in advance.
Posted By: i am an idiot
Date Posted: December 18, 2008 at 9:04 PM
To illuminate the ground so you can see to walk up to the vehicle.
Posted By: Mike M2
Date Posted: December 18, 2008 at 9:18 PM
This happens with the factory remotes too. I know on the Tahoe you can turn this feature on/off in the information center located on the instrument cluster. It's in the factory owners manual how to do it....
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: sinkhole
Date Posted: December 18, 2008 at 9:20 PM
The DTR lamps and reverse light will not come on if the truck has been remote started, only if its not running and I unlock with the remote. So I'm assuming the XK01 turns these lights on through the Data line? The other thing I just noticed is, if I unlock the truck with the key and start it with the key, The status LED continues to flash and will only shut off if I unlock the doors with the remote. I used the D2D connection from the XK01 to the 5101, if that helps.
Posted By: sinkhole
Date Posted: December 18, 2008 at 9:21 PM
Good to know. Thanks. My truck didn't come with factory remotes so I never experienced that.
