astrostart, 2003 gmc
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109864
Printed Date: March 29, 2026 at 8:55 AM
Topic: astrostart, 2003 gmc
Posted By: billmax
Subject: astrostart, 2003 gmc
Date Posted: December 18, 2008 at 9:15 PM
i just put in a astrostart on my buddies truck, it is a 2003 gmc sierra 2500, we used the astrostart rss-5224 and the by-pass modual xk01 with firmware amdl 6.00v.h1.s1.d2 the truck starts fine on remote but we can't seem to get the doorlocks to work. the manual is very poor in describing what wires to hook up from the astrostart to the modual. we bought this by-pass with the purpose of not having to go in the door panels. does anyone know what wires i need to hook up to make it work. i've put three prostarts in gmc with the gmdl modual and had no problems. this one has me stumpted. thanks
------------- billybob
Posted By: jrilla
Date Posted: December 18, 2008 at 9:30 PM
You need to hook up the Blue from the astrostart to the Blue on the XK01 and the Brown to the Green. The Blue/White and the BROWN / White from the Astrostart need to be grounded. The WHITE/ Blue and WHITE/ Brown are not used.
Posted By: billmax
Date Posted: December 21, 2008 at 8:43 PM
thankyou very much. to cold to wire it now. -35 makes sense that it should work. merry christmas
Posted By: billmax
Date Posted: January 07, 2009 at 8:07 PM
i put a astrostart rss-5224 in my buddies 2003 gmc 4wld auto trans pickup. i used the bypass xko1. everyting works great but he says that when he remote starts the trk it only shifts to 2nd gear, no higher, if he shuts it off and starts with key it works fine. i did hook up the 2nd ign wire. is it possible for the remote start to do this. any help is great. thankyou.
Posted By: ckeeler
Date Posted: January 07, 2009 at 8:31 PM
what wire did you hook the second ignition to? its possible you need to power (almost as sure as the sun will rise) that you need to power another wire as the second ignition or even add a third.
Posted By: loneranger
Date Posted: January 07, 2009 at 9:21 PM
Hopefully there is no damage to the tranny.
Posted By: billmax
Date Posted: January 07, 2009 at 10:48 PM
what extra wires do i have to hook up for a 2003 gmc 4wld auto, i put in a astrostart rss-5224 with a bypass xk01 and the auto trans will only shift into 2nd gear. i did hook up the 2nd ign and everything else works great. does anyone have the wiring info on this. thanks
Date Posted: January 07, 2009 at 11:06 PM
Is the check engine light on, during remote start?
Posted By: derekjbridges
Date Posted: January 13, 2009 at 1:00 AM
there are 2 ignition wires the pink & the white that need to be hooked up and also 2 accessory wiers that need to be hooked up the orange and the brown. I beleive the shifteng problem is coming from the second accessory wire not being hooked up
------------- -nosnvln-
Posted By: saskpuller
Date Posted: January 13, 2009 at 1:21 PM
Actually the brown wire does NOT need to be hooked up and the shifting issue is from the second ignition wire not being hooked up as an ignition (or not at all). This is common. Make sure to get it corrected immediately!
