02 sunfire remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109888
Printed Date: March 29, 2026 at 11:57 PM
Topic: 02 sunfire remote start
Posted By: nissanman98
Subject: 02 sunfire remote start
Date Posted: December 19, 2008 at 7:38 PM
Just bought a valet remote start and want to install myself could anybody tell me what bypass I need and any other tips to make this go smooth.
Bo
Posted By: tedmond
Date Posted: December 19, 2008 at 11:06 PM
passlock bypass is what you need. there are many to choose from. most popular brands would be Fortin, Bypasskits, idatalink, etc.
Posted By: chriswallace187
Date Posted: December 20, 2008 at 3:19 AM
Ignition switch harness wires are somewhat of a bitch. If you don't have a tilt column - take the shroud off, unplug the ignition harness, and pull the wires through to make your connections. If you have a tilt column, make the connections to the ignition harness upside down(you'll either break or severely scratch the tilt wheel lever trying to remove it).
Parking lights, brake lights, lock, unlock are all readily accessible in the orange taped harness to the rear on the driver's side. Driver's doorpin, if you feel like doing RAP shutdown or other need, is in a two pin harness going to the pin switch itself.
Wires through the firewall for tach/hoodpin: This is the easiest car in the world. Notice the gigantic 5" wide gray grommet that only has 1" of wires. Poke a hole and go through there, preferably dragging your wires with a coathanger.
Tach: regardless of what engine, look for the ignition module connector towards the driver's side. PURPLE / white wire.
C Renner's Auto Electronix
Posted By: kassdog
Date Posted: December 20, 2008 at 10:23 AM
Another tip is that you can get your ignition wires and p. lights at the harness going through the firewall. There is a little piece of loom that comes right off. Thats where I always grab my ignition and p. lights in the sunfire/cavalier. Also I've always like the 555lw by dei. Not sure if they still make that though.
Posted By: sonnyb
Date Posted: December 24, 2008 at 5:45 AM
I have sunfire 2001 Just want to check where can find th all the wires and what i need to open to reach the wires i have circuit diagram .Also i need to bypass the security of the car as well. I want to know what i need for that and where can i get the by pass module.
techi
