dei door lock actuators on civic ef ’90
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109897
Printed Date: March 30, 2026 at 4:56 AM
Topic: dei door lock actuators on civic ef ’90
Posted By: franckcrx
Subject: dei door lock actuators on civic ef ’90
Date Posted: December 20, 2008 at 7:16 AM
Hi.
With the help of this forum and the help of Hondatech, i installed my alarm the best way.
So thanks ;-)
Now, i want to add power door lock actuators (DEI 524) on my Civic EF9'90 (with power windows) on to the Hirnet 563T alarm.
Can someone tell me if i have to pass trough relays as some guys specialized in alarms here in Malta tells me not to ?
I personnaly think i need SPDT relays.
Can someone tell me how to plug my actuators
i have 1 green wire and 1 blue wire on the actuator, and 1 green and 1 blue on the alarm.
If i connect the blueS together and the greenS together, it wont work ?
Thank you for your help ;-)
Posted By: howie ll
Date Posted: December 20, 2008 at 12:02 PM
Green on alarm to 85, 12V+  at 25 amps (assuming 4 doors) to 86 and 87, 87a to ground and 30 to green lock wire on actuator (assuming it "pulls" down to lock). Blue on alarm to 85, 12V+  same feed as above, to 86 and 87, 87a to ground and 30 to blue unlock wire on actuator.
Date Posted: December 20, 2008 at 12:40 PM
Thank you ;-) i keep it in mind
To make it easier and cleaner, i am gonna get DEI 451M from US, as it is already hard to find SPDT relays here.
Posted By: joch1314
Date Posted: December 20, 2008 at 2:50 PM
With the DEI 451m it will be a little easier....Just connect it to your brain then 12V+ to the purple and PURPLE / black(they're more than likely already tied together).  BROWN / black and WHITE/ black go to ground.  Green black goes to the green wire of the actuator and blue/black goes to the blue wire of the actuator.  That should get you all set.
...half of the truth can be worse than a lie. <----Roger Russell said that..
Date Posted: December 20, 2008 at 3:01 PM
Thank you very much. It helps me A LOT
