08 santa fe, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109938
Printed Date: March 31, 2026 at 5:02 PM
Topic: 08 santa fe, remote start
Posted By: maxcat
Subject: 08 santa fe, remote start
Date Posted: December 21, 2008 at 7:44 PM
Hey all, Will be installing a r/s into a 08 Santa Fe shortly and was wondering, apparently you can grab the tach wire behind the instrument cluster. does anyone know how hard or the particulars to get  that front panel off. also was wondering if the bcm is easy to get to as well.
              Any insight or tips or past experience would be greatly appreciated
Posted By: jseibold
Date Posted: December 22, 2008 at 11:00 AM
Here is what Audiovox says...........
TachometerBLUE/ORANGE(AC)IN HARNESS IN PASSENGER KICKPANEL
It also has a note that the wire may be white.......otherwise you could use an injector wire-the uncommon color wire
Posted By: 05gt
Date Posted: December 23, 2008 at 5:29 PM
Can also go to any fuel injector and use the wire that is NOT pink or orange.
Posted By: tj durham
Date Posted: December 23, 2008 at 6:16 PM
on Hyundais I have found that the injector is a more reliable source and usually easier to fet to any way
Posted By: chadwa2003
Date Posted: December 23, 2008 at 6:38 PM
tach is blue/orange behind the cluster very easier to remove 2 screws on the shroud then 4 screws on the cluster. In hyundais the injectors are less reliable so it's better if you use the signal behind the cluster
