xk01 vs xk06
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=110045
Printed Date: April 03, 2026 at 10:28 AM
Topic: xk01 vs xk06
Posted By: bomax
Subject: xk01 vs xk06
Date Posted: December 25, 2008 at 8:55 PM
I am preparing to install the Viper 5601 alarm, and the shop that sold it to me recommended that I get the XK06 module, even though the Viper.com website recommends the XK01, and my vehicle (2008 Silverado) does not appear in the compatibility list for the XK06. They stated that the XK01 would not support remote start, and the XK06 is required for remote starting my vehicle.
My "new" understanding is that the XK01 would include everything that the XK06 does, but also add power door locks. I believe that if the module can control the locks through the databus, that would make the installation easier as I wouldn't have to manually tap into these wires.
Is that correct? Should I exchange modules?
Posted By: bomax
Date Posted: December 25, 2008 at 9:51 PM
After doing some further research it looks like the shop was correct and the websites were wrong? My truck is equipped with GM PASSKey III+, with the "plus," and the XK01 only bypasses GM PASSKey III, without the plus.
Is that right?
I will probably just get the 1701G as it looks to do just about everything I would need...
Posted By: dtk1
Date Posted: December 25, 2008 at 11:26 PM
1701g is the S#!t also try lookin into fortin modules www.ifar.ca the have some really good modules they offer a little bit more that DEI
Posted By: Mike M2
Date Posted: December 26, 2008 at 7:44 AM
Doing a search here will verify the "quality" of the XK-- modules. Every 4th thread is about a problem with them....
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: kgerry
Date Posted: December 26, 2008 at 1:15 PM
i don't have problems with XK modules at all.... but for this vehicle i would definately recommend the Idatalink piece.....
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: bomax
Date Posted: December 26, 2008 at 2:07 PM
Which Idatalink piece is that?
Posted By: kgerry
Date Posted: December 26, 2008 at 3:07 PM
ADS-DL & the ADS-RNG-GM3 it takes care of the MUX stuff so you dont need any extra relays or resistors......
Owner/Installer
Classic Car Audio
since 1979
Posted By: saskpuller
Date Posted: December 27, 2008 at 12:58 AM
Use the Idatalink module ADS-DLSL-GM3 c/w RNG-GM3. This takes care of the passlock and the PK3+. Doesn't require any wires to be cut which is a bonus. I quit using all the other kits when I found this one. Cutting a transponder wire scares me!
