door lock relay locations
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11008
Printed Date: April 18, 2026 at 2:07 PM
Topic: door lock relay locations
Posted By: rivermikerat
Subject: door lock relay locations
Date Posted: March 17, 2003 at 12:31 AM
I am installing a Viper 300ES from DEI on my 99 Escort. I am having trouble locating the relays for the electric locks. I know it has electric locks, since, upon removing the driver door panle, I discovered a lock solenoid. Can anyone help me in locating these relays?
Posted By: draasch
Date Posted: March 17, 2003 at 6:21 AM
Constant 12 volts BLACK/ ORANGE (2) IGNITION SWITCH HARNESS *
Ignition 12 volts GRAY / YELLOW IGNITION SWITCH HARNESS **
Starter BLACK/ L GREEN IGNITION SWITCH HARNESS ***
Dome Light RED / WHITE (-) 15 PIN GREEN CONN. BELOW FUSE PANEL
Trunk Pin Switch ORANGE / WHITE (-) AT LIGHT IN TRUNK **** SEE TECH
Parking Lamp RED / BLACK (+) 15 PIN GREEN CONN. BELOW FUSE PANEL
Power Lock BLUE EITHER KICK #201
Power Unlock GRAY PANEL
* Both BLACK/ ORANGE Wires Change To BLACK At Base Of Steering Column. ** GRAY / YELLOW Changes To BLUE At Base Of Steering Column. *** BLACK/ L GREEN Changes To RED / WHITE At Base Of Steering Column. **** Trunk Pin In Wagon Is RED / YELLOW (-) At Light In Trunk. #201- See Negative Pulse Door Lock Diagram.
Date Posted: March 17, 2003 at 10:43 PM
Thanks draasch. I appreciate the help.
