getting viper 790 remote start to work
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11009
Printed Date: April 18, 2026 at 1:44 PM
Topic: getting viper 790 remote start to work
Posted By: rmtphan
Subject: getting viper 790 remote start to work
Date Posted: March 17, 2003 at 12:31 AM
I got a 98 civic and i'm trying to get the remote start on a viper 790 to work.  I hook up the 5 remote start wire to the ign1, ign2, accor, starter, and 12+.  Then i ground the neutral safety wire.  I try getting it started and it wouldn't start up fully.  It'll try to crank but not enough cranking.  Do i need to hook up the Tach wire because i can't find the tach wire.  Please help me.  Thank you.
Posted By: oolowrideoo
Date Posted: March 17, 2003 at 5:46 AM
I had the same problem with my 02 Grand Am. Make sure you go through the "Tach Learning" procedure and you'll probably need to increase the crank time in the learning mode. Look in your install manual find out how to do this. If you still need help don't hesitate to contact me.
Ryan.Noble@adelphia.net
Posted By: cpgoose
Date Posted: March 17, 2003 at 7:19 AM
I would definitely hook up the tach wire, and then program your remote starter for tach. When I hooked up one in a '97 Civic, I grabbed the tach wire behind the tachometer in the dash. It was only a couple of screws, and the gauge cluster pulls out, and then I think it was the blue wire going to the tachometer. At first I didn't use tach, and the car would start maybe 2 out of every 5 tries. After I hooked up the tach, it always started. BE CAREFUL NOT TO MESS WITH THE WIRES IN THE YELLOW LOOM, I BELIEVE THOSE ARE THE AIRBAG WIRES.
Posted By: rmtphan
Date Posted: March 17, 2003 at 12:53 PM
LOL.  My car didn't came with air bag...the previous owner trash it...Thank you for the info btw, i'm gonna try it....Is the tach wire only a wire that control the cranking?....Just wondering about that.... O and do i need to hook up the brake wire to get the remote start working.  Thank for all your help.
Posted By: re2gie99
Date Posted: March 17, 2003 at 1:31 PM
You need to hook up the brake wire, because that is the wire used to let the brain know that you have pressed the brake after a remote start and lets the key operate the vehicle.
Posted By: JWorm
Date Posted: March 17, 2003 at 6:25 PM
The tach wire can't get much easier on a Civic. Its between the strut tower and the firewall in a connector with a black rubber cover on it. Its not plugged into anything and its a blue wire.
You can also get it at the instrument cluster, as stated above.
