compustar 1wam4r
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=110411
Printed Date: May 10, 2026 at 3:31 PM
Topic: compustar 1wam4r
Posted By: alex05
Subject: compustar 1wam4r
Date Posted: January 06, 2009 at 4:21 PM
my remote starter was working fine it was in the vehical when i bout it so i dont have a book or anything its a 98 jeep cherokee sport. it was working fine then just stoped working i replaced the batterys in the remotes nothing happens at all wont lock/unlock doors marker lights dont flash any ideas
Posted By: loneranger
Date Posted: January 06, 2009 at 4:25 PM
It's probably a fuse for the R/S. Before you replace it, diagnose why it blew in the first place.
Posted By: alex05
Date Posted: January 06, 2009 at 4:38 PM
i have checked all the fuses they are all good
Date Posted: January 06, 2009 at 4:57 PM
Are you sure you checked the module fuse and not just the relay fuses? Also, check the antenna connection. It's possible you have a defective module.
Posted By: alex05
Date Posted: January 06, 2009 at 5:34 PM
yes ive checked them all connections look good there is a button on the antenna if i push it my lights flash 3 times. some times after driving my power locks would quit and so would command start let it sit for a hour and everything would work fine agen
