95 mazda/ford b2300
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=110600
Printed Date: May 08, 2026 at 8:57 AM
Topic: 95 mazda/ford b2300
Posted By: rwilch
Subject: 95 mazda/ford b2300
Date Posted: January 12, 2009 at 8:21 PM
Hello all, trying to install a prostart in my truck, its my first standard transmission install and have a few questions on  1) How to wire a clutch bypass switch, conflicting information off of various sites and 2) this site says the neutral safety switch is not grounding - OEM switch opens starter circuit, just a little confused as to that meaning! Installing a Prostart 2 way alarm that I got from canadian tire.
Posted By: KarTuneMan
Date Posted: January 12, 2009 at 10:20 PM
OK, the first question (and I cannot beleive I'm the first to ask!) What are you installing?
Posted By: loneranger
Date Posted: January 12, 2009 at 10:27 PM
ProStart 2300B (R/S w/alarm)
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
Posted By: rwilch
Date Posted: January 13, 2009 at 1:26 AM
Posted By: rwilch
Date Posted: January 13, 2009 at 3:10 AM
everything is wired up, will enter ready mode but will not crank at all on command, I haven't put in the clutch bypass just yet but if I sit in the vehicle and hold the clutch in and try to restart it, the same end result - parking lights come on then go off!
