’08 outlander with fastkey
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=110734
Printed Date: May 09, 2026 at 11:04 PM
Topic: ’08 outlander with fastkey
Posted By: mxxmikexx
Subject: ’08 outlander with fastkey
Date Posted: January 17, 2009 at 7:53 AM
is the 08 wiring the same as the 09? im assuming so, but would like to make sure.
I read on here you can grab locks in the drivers kick, negative pulse
other forums say you need a data interface for locks (fortin can sl2)
customer already has remote start/keyless unit. i plan on using one of his emergency keys in a keybox, hopefully grabbing locks in the kick, and calling it a day. only other little thing you gotta do is open up the "keysense circuit" correct?
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
Posted By: Big Dog
Date Posted: February 10, 2009 at 2:51 PM
For push to start systems: Use a 556U and one OEM TX with battery removed. If you leave battery in TX then car will not start because it would require pressing the start knob - don't use 1101T.
Lock = WHITE/ Black (-) in brown plug in driver's kick.          Unlock = RED / Tan (-) in brown plug in driver's kick.
Some Outlanders don't have wires for factory alarm arm/disarm. In that case the alarm arms on lock with the door open, and disarms with ignition and the keysense wire being cut.
Prepare your future. It wasn't the lack of stones that killed the stone age.
