2008 liberty bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=110758
Printed Date: May 10, 2026 at 9:44 AM
Topic: 2008 liberty bypass
Posted By: offroadzj
Subject: 2008 liberty bypass
Date Posted: January 17, 2009 at 8:06 PM
Does anyone know of a keyless/data bypass I can use for the mux/transponder in my wife's 08 liberty? The dealership wants $150 for just the cut key (not programmed) so I want to check out my options before I go spending it. I have the DLPK for the locks, alarm, tach, door pin, hood pin, etc. I am looking at 1 of them right now... the canmax400 which looks pretty sick, but i have had no experience with them at all. Any info would be appreciated.
Kenny
------------- Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Date Posted: January 17, 2009 at 10:01 PM
i did some further research and found an audiovox FL532 bypass that did both transponder and data. Anyone use these before? Are they reliable?
------------- Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Posted By: xghost
Date Posted: January 17, 2009 at 10:12 PM
They all work but if I may just make a suggestion. Id recommend using ADS. There ADS DLSL CH3 is a great module all in one. But the one you listed should work. Good luck.
