07 trailblazer, viper 571xv, xk01
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=110817
Printed Date: March 28, 2026 at 3:04 AM
Topic: 07 trailblazer, viper 571xv, xk01
Posted By: ralph_t
Subject: 07 trailblazer, viper 571xv, xk01
Date Posted: January 19, 2009 at 6:46 PM
Hello,
I just finished hooking up the Viper 571XV to my girlfriends 07 Trailblazer. Everyhting works except for a few issues noted below. I would appreciate someone helping me out on this.
1.  I do not know for cetain where the Brown Pin 1 on the XK01 should be connected to on the Viper 571XV.
2. How do I get the rear doors to unlock.? Apparently the XK01 only senses the front two doors using the OBDII wire.
3. Parking lights. I don't know where to connect this to. The XK01 is supposed to do this for me but it won't work.
4. When I remote start the car and put the key in the ignition and turn it to unlock the column the remote start does not disable. Because when I turn the key off the engine still runs.
Would appreciate any assistance on these issues. Thank you.
Posted By: another-kelly
Date Posted: January 19, 2009 at 9:39 PM
to the blue (status) or the blue/white (2nd status) on the viper unit. those are the ground when running status outputs from the viper
might check your programming, the xk01 is supposed to lock/unlock all 4 doors and the rear hatch
the xk01 does not take care of the parking lights for you. you need to change the jumper for parking light flash on the viper from positive to negative, then connect the white wire from the viper to:
Parking Lights          GREY/BLACK          (-)          AT SWITCH     OR BCM TAN PLUG PIN E5
the remote start won't shut down until you depress the brake to shift the vehicle out of park. simply cycling the key in the ignition will not shut off the remote start
Posted By: ralph_t
Date Posted: January 22, 2009 at 1:20 PM
This is how I had it so no adjustment neccessary. Thanks!
Hmm. I checked the manual. There is only a reference for hooking up the domelight. Supposedly because any door that opens triggers the domelight to come on. Does this sound right?
I got it to work! however it was a 50/50 chance as there are two wires of  the same color code (grey/BLACK/ ).
Noted, I noticed it does the same thing with my Viper 161 as well
One additonal question. When I press the lock and unlock or remote start buttons I get great feedback from the remote if the car recieved a signal but this is hit or miss. Sometimes I need to press the combo for remote start more than once and multiple times.
Posted By: ralph_t
Date Posted: January 22, 2009 at 1:25 PM
Oh I forgot. Does this mean that I need a new battery?
