diag. 4 window module,Velocity(Jeff)?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11083
Printed Date: April 18, 2026 at 2:07 PM
Topic: diag. 4 window module,Velocity(Jeff)?
Posted By: solarcrew
Subject: diag. 4 window module,Velocity(Jeff)?
Date Posted: March 18, 2003 at 2:27 PM
Jeff or anyone that can help.I need wiring diagram for crimestopper cs5101 pw module.I found one for the 5201 but its different wiring.I pulled the cs5101 and the alpine 8026A out of my vehicle.Kept running the battery down.Now my power windows won't work.The windows are aftermarket in an 87'4runner.I need to know which wires went where.If you have a diagram,plez post the link here,since my outlook xpress deletes any attachments.I don't know how to change it.Thnx in advance for any help.Doug
Posted By: themagicone
Date Posted: March 18, 2003 at 2:35 PM
DId you have switches for the windows before you put in the moudle? If you did baicly there should be 2 wires for each window. If you put 12vlts on one and ground on the other is should ethier close or open and vice versa, 12vlt on the other and ground on the other one. What color wires do you have hanging in your car that goes to the windows?
Posted By: Velocity Motors
Date Posted: March 18, 2003 at 2:39 PM
You should have matching colored wires from the switch to the motor. Find the matching colors and wire back the motor to the switch.
------------- Jeff
Date Posted: March 18, 2003 at 6:05 PM
Thnx for the replies.Everything was installed in the vehicle b4 I bought it.I was thinking about maybe getting a different alarm an using the pw module with that alarm.That's why I was hoping for the diagram.If you do have one,could you plz post the link.thnx again.Doug
Date Posted: March 18, 2003 at 8:31 PM
Ok,I wired the power windows back to the original wiring.Still doesn't work.I ran 12v straight to the window motors,they both work,up and down.Is it possible they were using the alpine 8026a or the crimestopper cs5101 as the main control for the windows,seeing how they are aftermarket pw's.If so,do I have alternatives,can I just hook the cs5101 up or do I need to hook them both back up.thnx,Doug
