2007 grand caravan
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=110954
Printed Date: April 19, 2026 at 6:35 PM
Topic: 2007 grand caravan
Posted By: triniforever
Subject: 2007 grand caravan
Date Posted: January 24, 2009 at 5:49 PM
Do you have to connect the yellow starter wire on this vehicle,from the starter output from the remote starter?
------------- triniforever
Posted By: monty_77
Date Posted: January 24, 2009 at 6:16 PM
That vehicle has two starter wire and both have to be connect for it to start.
the starter wire from the R/S will have to go to the Yellow + starter of the van.
The second starter wire is PURPLE / brown and will need to be grounded with a 180 ohm resister at time of starting . Note that some bypass kit will do that for you.
most of them bypass will have you hook a wire to the starter wire of the R/S but from my under standing you will still have to hook up the yellow starter wire
Date Posted: January 24, 2009 at 6:37 PM
i know the second starter wire PURPLE / brown also called the mux wire has to be hooked up to a relay with the resistor but i wasn't sure about the yellow wire ...............thank for the reply
Posted By: Chris Luongo
Date Posted: January 25, 2009 at 10:04 AM
Yellow: definitely.
PURPLE / brown: 2004-up Chrysler vans will start just fine even if you don't hook it up, but it's not a bad idea to connect it anyway.
Date Posted: January 25, 2009 at 11:29 AM
thanks for the info chris
