tach wire for 2007 navigator
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=111001
Printed Date: April 18, 2026 at 2:21 PM
Topic: tach wire for 2007 navigator
Posted By: viden_s
Subject: tach wire for 2007 navigator
Date Posted: January 25, 2009 at 10:06 PM
hi i spend 4 hours trying to find the tach wire could some one anyone please tell me the wire color and location for the tach in a 2007 lincoln navigator thank you very much
Posted By: chev104275
Date Posted: January 26, 2009 at 7:01 AM
Never used one on this truck done 10 or so    doesnt it start itself when you tap the key to start ?     if you wanted tach the uncommon side of any fuel injector should work fine or coil
Posted By: monty_77
Date Posted: January 26, 2009 at 8:01 AM
YELLOW /GREEN at ignition coil
Posted By: viden_s
Date Posted: January 26, 2009 at 6:33 PM
yea but the remote starter i use  need a tach signal wire it keep shutting down when it did not sense the wire
