viper 5701 honda civic 05
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=111104
Printed Date: April 02, 2026 at 7:43 PM
Topic: viper 5701 honda civic 05
Posted By: fremanc
Subject: viper 5701 honda civic 05
Date Posted: January 29, 2009 at 11:44 AM
Need Help with my viper alarm can someone tell me the correct wires that to go to wat as violet hooks to this n color , and also my 556hw bypass, need some help with that also
Posted By: KarTuneMan
Date Posted: January 29, 2009 at 11:28 PM
Take it to a shop and have it done correctly
Posted By: loneranger
Date Posted: January 30, 2009 at 11:00 AM
Please be more specific.
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
Posted By: fremanc
Date Posted: January 30, 2009 at 1:53 PM
i jus basically need the ignition points like the color wires on the car to what wire on the alarm
Alarm = car
Pink- Ignition 1 Input/output = ?
RED / White 30 a fused ignition2/flex relay,pin 87 input = ?
Orange Accessory = ?
Violet - Starter Output = ?
Green Starter Input = ?
Red - 30 amp fused ignition 1 relay input= ?
Pjnk/White - ignition 2 Flex relay output = ?
Pink/Black - 87a Ignition 2/Flex relay = ?
Red Black - 30a fused accessory/starter relaye input=?
i jus wanna make sure wat i have is correct thanks if u can help
Posted By: t&t tech
Date Posted: January 30, 2009 at 4:47 PM
pink ignition one output/input- this wire connects to the wire from the main ignition harness that reads 12volts when the key is in the on position and also has 12 during cranking the starter and 12 after the car has started, ( most likey the colour is BLACK / YELLOW, it's a thick gauge wire)
RED / white to constant 12 volts (most likely it's white, thick gauge)
orange to the wire that reads 12 when the key is in the acc position( can't remember off hand)
the wire that reads 12 volts only during cranking is your starter wire cut it in half (most likely the colour is BLACK/ white) the green wire goes to the side from the keyswitch, and the purple to the other side
red- constant 12 volts
RED / black to conatant 12 volts
the rest of the wires you won't need for this car, twist back the ends and insulate with tape,
test all your wires to verify,
