schematics needed, 2000 dodge durango
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=111175
Printed Date: April 05, 2026 at 2:04 PM
Topic: schematics needed, 2000 dodge durango
Posted By: edaddee
Subject: schematics needed, 2000 dodge durango
Date Posted: January 31, 2009 at 11:46 AM
For anyone that can provide exact schematics(drawn diagram) for a 2000 dodge durango, for alarm/remote start for the diodes/relays (as i'm a novice at installing alarms), I would greatly appreciate it as I will be leaving monday going out of town to do a few alarm/remote installs, but have never had one that needed multiple extra diodes/relays to work. Thanks in advance
Posted By: robertsc
Date Posted: January 31, 2009 at 1:12 PM
look above its says vehicle wiring
or try the search option
Posted By: edaddee
Date Posted: January 31, 2009 at 2:54 PM
already got the detail of the wiring itself, but i can't find anything other than what ohm resistors to wire in and that i need relays. like i said, just a novice @ the alarm/convenience installs. Also, i did multiple searches using dif keywords, but no luck thus far
Posted By: edaddee
Date Posted: January 31, 2009 at 3:13 PM
also, can anyone tell me how to wire multiple resistors to get the ohm value needed for installation? and within what tolerance can they be?
Posted By: edaddee
Date Posted: February 01, 2009 at 12:47 PM
anyone, please? leaving tom, mid-day, and i'd rather have something to go off of, than to be guessing
Posted By: robertsc
Date Posted: February 01, 2009 at 2:45 PM
theres lots of info here try looking around i know it make take several minutes
but its here
Posted By: i am an idiot
Date Posted: February 01, 2009 at 3:30 PM
The tolerance of most door lock systems is pretty forgiving, I have seen them be as far as 20% out and still work.
posted_image
Posted By: edaddee
Date Posted: February 01, 2009 at 3:40 PM
but its here
i'm sure the answers to the questions i'm asking may be here, but the phrase or keywords i'm using to search with just aren't pulling up what i need. I was under the assumption that if I couldn't find the answer after searching, I was entitled to ask a question, to see if someone that might actually know the answer could steer me in the right direction or share the knowledge they have, not back to the search option.
I appreciate all the "help"
Date Posted: February 01, 2009 at 4:04 PM
posted_imagePower UnlockGREEN/ ORANGE(-)HIGH IN DRIVERS KICK IN BLACK PLUGposted_image
posted_imagePowerLockSAME WIRE(-)HIGH IN DRIVERS KICK IN BLACK PLUG
LOCK/ARM IS NEGATIVE TRIGGER THRU A 650 OHM RESISTOR. UNLOCK/DISARM IS NEGATIVE TRIGGER THRU A 1560 OHM RESISTOR. MUST USE RELAYS. UNLOCK REQUIRES A DOUBLE PULSE.
Posted By: edaddee
Date Posted: February 01, 2009 at 10:05 PM
thanks, i am an idiot, I appreciate the quick response and help on the subjects at hand. Like i said, i'm just a novice, so it really helps
