command start cs 395i
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=111226
Printed Date: April 04, 2026 at 3:37 AM
Topic: command start cs 395i
Posted By: edram
Subject: command start cs 395i
Date Posted: February 01, 2009 at 5:07 PM
  My problem is the indicator light on the receiver remains steady,so that it won't start the engine but lock and unlock features work.I tried flashing the hood,i.e...press and hold pin for four sec,then press again once...no respond on the parking light....,ignored and continue with the brake pedal..still no respond  on the parking lights and horn.Please help or help with the schematics.THANKS.
Edilberto Ravelo Manlig
Posted By: Big Dog
Date Posted: February 10, 2009 at 3:25 PM
1. With the key in the Ignition switch, turn the key to the ON (RUN/IGNITION) and then OFF positions 5 times within 10 seconds.
2. The Parking Light will flash 2 times indicating the Module is now out of Valet Mode. The LED will turn OFF.
Prepare your future. It wasn't the lack of stones that killed the stone age.
Posted By: edram
Date Posted: February 11, 2009 at 12:26 PM
Hi..thanks for the input..I did tried it several times..and still the same,the LED receiver is always on.I notice too that the parklights will flash sometimes or will I'm thinking of not flash at all when I'doing the lock and unlock functions.I' thinking of troubleshhoting the in and out voltages,but I don't have the proper schematics.It is a COMMAND START 395i and the car is a1992 Acura V6.Thank you.
Posted By: edram
Date Posted: February 14, 2009 at 8:58 PM
You know..it's my friend's car and he did on and off but not in the off position but lock. position, so somehow it did not work;I then did it carefully and it worked.Thank you very much...the parklights trouble ..I'll maybe just resolder the stakes and hopefully fix his problems...Thank you so much.
