08 suzuki grand vitara wiring wanted
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=111359
Printed Date: May 09, 2026 at 4:20 PM
Topic: 08 suzuki grand vitara wiring wanted
Posted By: Johnnynguyen20
Subject: 08 suzuki grand vitara wiring wanted
Date Posted: February 06, 2009 at 8:29 AM
hello, does anyone have a wiring diagram for this 2008 Suzuki Grand Vitara. thanks for your help.
Johnnynguyen
Posted By: chev104275
Date Posted: February 07, 2009 at 8:37 AM
Remote Start
WIRE COLOR POLARITY LOCATION
Battery WHITE/ RED (+) IGNITION SWITCH HARNESS
Ignition 1 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
   THE STARTER WIRE IS ALSO BLACK / YELLOW, BE SURE TO TEST THESE WIRES
Accessory 1 YELLOW (+) IGNITION SWITCH HARNESS
Accessory 2 BLUE (+) IGNITION SWITCH HARNESS
Starter 1 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
   THE IGNITION WIRE IS ALSO BLACK / YELLOW, BE SURE TO TEST THESE WIRES
Anti-Theft Type UNIVERSAL IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense BLUE/RED (+) IGNITION SWITCH HARNESS
Tachometer PINK (AC) AT FUEL INJECTOR #1
   ALSO AT ECM MODULE UNDER HOOD
Speed Sense BLUE/BLACK (AC) AT ABS CONTROL MODULE UNDER HOOD TOWARDS FRONT CENTER OF COMPARTMENT
Parking Lights RED / YELLOW (+) IN HARNESS IN DRIVER KICKPANEL
Low Crr. Pk Lights RED / BLUE (-) AT VEHICLE HEADLIGHT SWITCH
Brake Lights GREEN / WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights RED (+) IN HARNESS IN DRIVER KICKPANEL TO REAR
Horn BLUE (-) AT BCM MODULE IN DRIVER KICKPANEL
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock PINK/GREEN (-) IN HARNESS IN DRIVER KICKPANEL
PowerLock PINK/BLACK (-) IN HARNESS IN DRIVER KICKPANEL
for the parking lights i use the RED / yellow at the fuse box bottom right connector positive trigger posted_image good luck
