antitheft device, 99 grand cherokee
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=111401
Printed Date: May 09, 2026 at 2:48 PM
Topic: antitheft device, 99 grand cherokee
Posted By: steveandtracy7
Subject: antitheft device, 99 grand cherokee
Date Posted: February 08, 2009 at 8:59 AM
I have a 99 jeep grand cherokee. It has an antitheft device where I have to put a small round metal pin key into a metal hole under my dash so I can enable starting the car. If I don't get the pin key exactly into the hole the car won't start. It has become such a nuisance that I would like to disable this device. Can someone please tell me what this device is called and how to disable it? I think it has 5 wires running into the back of this small black device. I have tried doing research on it and I can't find any info on it. Thanks
------------- steve
Posted By: howie ll
Date Posted: February 08, 2009 at 9:34 AM
It's an imobiliser, assuming you are in UK, forget te wires you mentioned, the main unit is probably up behind the instrument panel. It wil have 2 grounds, 3 ignition 2 starter and 1 power supply all coloured black. The ign or fuel line and starter need to be rejoined and the box thrown away. I remove three or four a month. Totally irrelevant on modern vehicles. Just be aware you might have negated your insurance if you are in UK or parts of Canada.
