528T for windows?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11146
Printed Date: April 18, 2026 at 8:31 PM
Topic: 528T for windows?
Posted By: grundler1975
Subject: 528T for windows?
Date Posted: March 19, 2003 at 5:59 PM
i have a 97 328i convertible bmw, Can I use a 528T or 2 to send a pulse to the switch in the dash that runs the top and the windows? If you hold the button it will put all 4 windows down and the top and it will put all 4 windows up and the top! I have a 530T but I'm not sure I need that sinch I have one touch already andI don't think I could hook up all 4 windoes anf the top to it. By the way the top is touchless and it latches and unlatches itself.
Posted By: AlarmTech
Date Posted: March 20, 2003 at 8:58 PM
i don't see why not, although a 529T may not even be needed, depending on the alarm you have, a timed or validity output AUX channel could work as well. Also, since i'm 99.9% sure the switch is just a link to a control module, the 529T may not even work.
you'd have to test the dash switch wire(s) for their (its) operation. and that will determine what is to be used (if possible) to duplicate the switches action.
check for polarity when pressed, as well as voltage.
Viper Equipped
