how to disengage my viper alarm?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=111556
Printed Date: May 08, 2026 at 3:52 AM
Topic: how to disengage my viper alarm?
Posted By: toughluckmobile
Subject: how to disengage my viper alarm?
Date Posted: February 13, 2009 at 2:22 AM
I recently bought an 89 Suburban that has a viper alarm system installed, and it goes off at total random. I want to completely disengage it, is there anyway I can just cut a wire and get on with life lol? If so where are the brains or main power wire for these things usually installed?
Posted By: howie ll
Date Posted: February 13, 2009 at 2:30 AM
Brain under dash, cut red wire or disconnect fuse that should be in that wire.
Date Posted: February 13, 2009 at 2:32 AM
K thanks for the info, its gone off a few times tonight im sure the neighbors arnt happy.
Posted By: t&t tech
Date Posted: February 14, 2009 at 5:56 PM
if it's triggering without cause then, there are two possible causes your shock sensor needs lowering or one of the contacts for either doors,hood or hatch needs fixing, if you haven't already disconnected like howie advised, then there should be a valet button somewhere ( a small black push type button, normal places are the driver kick, under steering or glove compartment), just simply turn on the ignition turn it off and tap the button once and that will put the alarm in valet mode until you can rectify ur probs.
Date Posted: February 14, 2009 at 11:04 PM
thanks for the info guys..took all put 2 seconds to locate the brain and pull the fuse.
Good info t&t but I was wanted to get rid of the system anyway, im installing radio equiptment that puts out some serious RF that probably wouldnt get along with the alarm system anyway.
