1995 Toyota Camry Keyless Entry Help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11178
Printed Date: April 18, 2026 at 9:44 PM
Topic: 1995 Toyota Camry Keyless Entry Help
Posted By: SerialOne
Subject: 1995 Toyota Camry Keyless Entry Help
Date Posted: March 20, 2003 at 2:10 PM
I put in a keyless entry remote start on my dad's Camry.  The keyless was working fine uptil about a week ago.   Now the keyless doesn't work at all.  From the switch inside the car I can unlock the car that's about it, it won't lock at all.  That includes the switch on both front doors.  But it will still lock with the key from the outside.
I tested the lock wire and there was no voltage at all, but the unlock wire still registering 12v.
The unit is a Prostart CT-3300.
I also unplugged the lock/unlock wires and the switch still does nothing.  I also hooked up the unlock wire with diodes for the child safety wire.
Posted By: draasch
Date Posted: March 21, 2003 at 2:58 PM
Constant 12 volts WHITE AND WHITE/ RED IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ ORANGE IGNITION SWITCH HARNESS
Starter BLACK/ WHITE IGNITION SWITCH HARNESS
you need to doulbe check all of your hook ups.
use the info below....
do not use a test light to check your wires!
use a meter.
Dome Light RED / WHITE (-) FUSE/RELAY BLOCK - DRIVER KICK PANEL
Trunk Pin Switch RED / WHITE (-) TRUNK LIGHT OR PIN SWITCH
Parking Lamp GREEN (+) AT FUSE/JUNCTION BLOCK ("TAIL"FUSE)
Power Lock L GREEN BLUE 20 PIN CONNECTOR
Power Unlock D GREEN IN DRIVER KICK PANEL #209
#209- See Child Safety Locks Diagram. * Child Safety Locks- BLUE/RED At Pin #9 In Same Connector As Door Lock Wires Above.
let us know what you find out....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Date Posted: March 21, 2003 at 4:51 PM
I used a multi-meter to check for voltage.
That's what I have everything hooked up to.  The lights still flash but the doors won't lock or unlock.  Also the door lock switch does not work anymore either.  I think it's just the power door lock relay.
Date Posted: March 21, 2003 at 4:58 PM
Also the outputs from the module are both negative outputs for the lock and unlock outputs.
Posted By: thomas_51c
Date Posted: March 21, 2003 at 5:27 PM
I know this sounds simple but did you check all of you're fuses. I had the door locks going crazy on me on a recent install. It turned out there were two door lock fuses and one was blown.
