viper 5701 in 08 nissan 350z
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=111794
Printed Date: May 09, 2026 at 9:05 AM
Topic: viper 5701 in 08 nissan 350z
Posted By: majestic1
Subject: viper 5701 in 08 nissan 350z
Date Posted: February 21, 2009 at 9:27 AM
hello installers out there. i need some assistant with an alarm/remote start alarm system. i am trying to get the viper 5701 remote start feature to work on a 2008 nissan 350z. when i go to hit the remote start button the "f" button lights & buzzes and the alarm does nothing.
i haven't installed one of these newer systems before and i need help. everything else on the alarm works except the remote start. i have the xpresskit dlpk interface connected and that all seems fine. can anyone verify what wires from h/3 harness go to what and which ones aren't needed.
i know this car has a second starter that needs to be connected, no second ing. so, help me out guy!
viper 5701
------------- Majestic Motorsports
Posted By: JWorm
Date Posted: February 21, 2009 at 9:47 AM
Is the car au automatic or manual? Is the remote start programmed for automatic or manual? Have you connected the neutral safety input wire to anything?
Date Posted: February 21, 2009 at 11:56 AM
The 2008 350Z is an automatic, and the neural safety switch is grounded. I didn't check to see if it was programed for auto trans. I didn't know it came default for manual. That might be one reason why it's not working. Can you also verity the H3 harness too.
Date Posted: February 21, 2009 at 1:15 PM
Posted By: JWorm
Date Posted: February 21, 2009 at 2:45 PM
They come programmed for manual. You need to switch that.
I'm too lazy to look up the tech sheet, but most Nissans have 1 ignition, 2 starters, and 1 or 2 accessory wires.
H3
1 Pink -> Ignition of car
2 RED / white -> Constant wire in car
3 Orange -> Accessory 1 of car
4 Violet -> Starter side of main starter wire
5 Green -> Key side of main starter wire
6 Red -> Constant wire in car
7 Pink/white -> Starter side of 2nd starter wire in car
8 Pink/black -> Key side of 2nd starter wire
9 RED / black -> Constant wire in car
Make sure you go into the programming menu and change the output of the flex relay to "Starter 2"
If there is a 2nd accessory wire in the car that needs to be connected (most Nissans don't need it, even though DEI puts it on their tech sheets) then I would add a relay for it and trigger the relay with the orange (-) acc output in the 5-pin aux output harness.
Posted By: money042
Date Posted: November 28, 2009 at 9:55 AM
Sorry to bring back an almost year old thread. I'm diy'ing a Python 991 on my '07 G35 coupe (should be exactly the same as a 350z.) and needed some clairifcation. After reading JWorm's post, is it safe for me to assume that I can directly hook up #7 Pink/White and #8 Pink/Black to the 2nd starter without a relay (for some reason, I can't grasp the function of a relay)? That's not the same as combining 1st starter and 2nd started and connecting both to #4 & 5, is it?
