2008 toyota landcruiser remote start wiri
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=111959
Printed Date: March 27, 2026 at 8:12 AM
Topic: 2008 toyota landcruiser remote start wiri
Posted By: superklepto2000
Subject: 2008 toyota landcruiser remote start wiri
Date Posted: February 26, 2009 at 7:53 PM
hi guys i'm trying to install an remote start alarm in a 2008 toyota landcuiser but it has a transponder key there is no ignition switch just a start button . can anyone help me with a bypass method? and where to find the correct wires
thanks in advance
regards,
marvin
Posted By: Mike M2
Date Posted: February 27, 2009 at 7:41 PM
| Battery | | RED | | (+) | | AT VEHICLE BATTERY | | | Starter 1 | | BLACK | | (-) | | AT ENGINE START BUTTON IN DASH | | | LF Latch | | BLUE | | (-) | | AT MODULE UNDER DRIVER SIDE DASH | | | RF Latch | | YELLOW | | (-) | | AT MODULE UNDER DRIVER SIDE DASH | | | LR Latch | | WHITE | | (-) | | AT MODULE UNDER DRIVER SIDE DASH | | | RR Latch | | GREEN | | (-) | | AT MODULE UNDER DRIVER SIDE DASH | | | Trunk Trigger | | WHITE | | (-) | | AT MODULE UNDER DRIVER SIDE DASH | | | Alarm Disarm | | YELLOW | | (-) | | AT MODULE UNDER DRIVER SIDE DASH | | | | | METER THIS WIRE WHILE TURNING THE KEY IN THE DRIVER DOOR CYLINDER | | | Parking Lights | | GREEN | | (+) | | AT MODULE UNDER DRIVER SIDE DASH | | | Low Crr Pk Lights | | VIOLET | | (-) | | AT VEHICLE LIGHT SWITCH |
| Headlights-Lo | | RED | | (-) | | AT VEHICLE LIGHT SWITCH | | | LF Pk Lt Bulb | | GREEN | | (+) | | FRONT LEFT PARKING LIGHT | | | RF Pk Lt Bulb | | GREEN | | (+) | | FRONT RIGHT PARKING LIGHT | | | LR Pk Lt Bulb | | GREEN | | (+) | | REAR LEFT PARKING LIGHT | | | RR Pk Lt Bulb | | GREEN | | (+) | | REAR RIGHT PARKING LIGHT | | | All Hazrd Lights | | ORANGE | | (-) | | AT VEHICLE HAZARD SWITCH | | | LF Hazrd Bulb | | BLUE | | (+) | | AT FRONT LEFT TURN LAMP | | | RF Hazrd Bulb | | RED | | (+) | | AT FRONT RIGHT TURN LAMP | | | LR Hazrd Bulb | | BLUE | | (+) | | AT REAR LEFT TURN LAMP | | | RR Hazrd Bulb | | RED | | (+) | | AT REAR RIGHT TURN LAMP | | | Wipers-Lo | | GREEN | | (+) | | AT WIPER CONTROL SWITCH | | | Wipers-Hi | | RED | | (+) | | AT WIPER CONTROL SWITCH | | | Parking Brake | | YELLOW | | (-) | | AT PARKING BRAKE SWITCH | | | Trnk Release | | BLUE | | (-) | | AT TRUNK RELEASE SWITCH | | | Seat Mem 1 | | GREEN | | (-) | | AT MEMORY SEAT SWITCH | | | Seat Mem 2 | | RED | | (-) | | AT MEMORY SEAT SWITCH |
| Battery | | RED | | (+) | | AT VEHICLE BATTERY | | | Starter 1 | | BLACK | | (-) | | AT ENGINE START BUTTON IN DASH | | | Anti-Theft Type | | UNIVERSAL IMMOBILIZER | | | Anti-Theft Descript | | THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER | | | Tachometer | | WHITE | | (AC) | | AT MODULE UNDER DRIVER SIDE DASH | | | Speed Sense | | VIOLET/WHITE | | (AC) | | AT SKID CONTROL ECU | | | Parking Lights | | GREEN | | (+) | | AT MODULE UNDER DRIVER SIDE DASH | | | Low Crr. Pk Lights | | VIOLET | | (-) | | AT VEHICLE LIGHT SWITCH | | | Brake Lights | | RED | | (+) | | AT SWITCH ABOVE BRAKE PEDAL | | | Reverse Lights | | BLUE | | (+) | | IN HARNESS TO REAR | | | Horn | | RED / WHITE | | (-) | | AT MODULE UNDER DRIVER SIDE DASH | | | Rear Defrost | | GREEN |
| Power Unlock | | YELLOW | | (-) | | AT MODULE UNDER DRIVER SIDE DASH | | | | | METER THIS WIRE WHILE TURNING THE KEY IN THE DRIVER DOOR, REQUIRES A DOUBLE PULSE TO UNLOCK ALL DOORS | | | PowerLock | | LIGHT GREEN | | (-) | | AT MODULE UNDER DRIVER SIDE DASH | | | | | METER THIS WIRE WHILE TURNING THE KEY IN THE DRIVER DOOR | | | LF Window Up | | BLUE | | (REV) | | DRIVER WINDOW CONTROL SWITCH | | | LF Window Dn | | BLACK | | (REV) | | DRIVER WINDOW CONTROL SWITCH | | | RF Window Up | | BLUE | | (REV) | | PASSENGER WINDOW CONTROL SWITCH | | | RF Window Dn | | BLACK | | (REV) | | PASSENGER WINDOW CONTROL SWITCH | | | LR Window Up | | BLUE | | (REV) | | REAR LEFT WINDOW CONTROL SWITCH | | | LR Window Dn | | BLACK | | (REV) | | REAR LEFT WINDOW CONTROL SWITCH | | | RR Window Up | | BLUE | | (REV) | | REAR RIGHT WINDOW CONTROL SWITCH | | | RR Window Dn | | BLACK | | (REV) | | REAR RIGHT WINDOW CONTROL SWITCH | | | Sunroof Open | | PINK | | (-) | | SUNROOF CONTROL SWITCH | | | Sunroof Close | | GREEN | | (-) | | SUNROOF CONTROL SWITCH | |
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: Mike M2
Date Posted: February 27, 2009 at 7:46 PM
Also, Idatalink makes a module that you will need for bypassing the imobilizer and work the push to start. Go to thier website and punch in the type of car and look at the instructions. They aren't very hard...
Tech Manager
CS Dealer Services
