recommendation for ’94 bmw k/e, r/s, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=111970
Printed Date: March 27, 2026 at 1:20 PM
Topic: recommendation for ’94 bmw k/e, r/s, etc.
Posted By: mlasarko
Subject: recommendation for ’94 bmw k/e, r/s, etc.
Date Posted: February 27, 2009 at 6:22 AM
Greetings,
I have seen a few posts regarding aftermarket BMW alarms, keyless entry, remote starters, etc... some with the window controls, others with the windows and sunroofs. However I do not see many recent post for my year/model...
The ride is a 1994 BMW 740i - I do not *need* remote start, if I have it great, if not the k/e, windows, etc... would be nice. Is there is a reliable/proven system that does all of this well?
Any recommendations of what to look at, or NOT to look at would be appreciated.
Thanks!
~M
Posted By: Velocity Motors
Date Posted: February 28, 2009 at 10:54 AM
There won't be a system out there that has all those optional modules included unless you purchase it from a reputable shop. My suggestion would be to go with a Compustar PRO 2WFM alarm ( with the CM5000 CPU ) and then add the modules that you want to control the windows & sunroof. The door locks and trunk release controls are installer options that are already available on the CM5000 but need to be installed by the installer.
If you want full control over individual windows then you will also need the channel expander. If you only want control of all windows UP and DOWN, then no channel expander is required as the CM5000 already has 2 AUX channels that you can use for this.
