any way to disable the factory alarm?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=112020
Printed Date: March 28, 2026 at 12:04 AM
Topic: any way to disable the factory alarm?
Posted By: jrprich
Subject: any way to disable the factory alarm?
Date Posted: March 01, 2009 at 5:22 PM
99 Chrysler Town & Country Ltd.
I am new to this forum and I did search this topic first.
I am hoping someone can point me in the direction of how to disable the factory alarm without me having to get a new BCM on my 99 T&C Ltd. It has become even more unpredictable now.
If the car is locked and you use the key to unlock the rear hatch it will alarm. Today I unlocked the drivers door first, but did not open the door, then opened the hatch and it went off again.
My wife will not drive the van now as it has gone off on her at the grocery twice.
I do not have a working factory fob. I tried twice to get a Chrysler dealer to program a new fob for the car but their efforts failed twice.
No luck on my Chrysler forum so I did a Google search and found this link on this site
installbay/detail/668.html
I thought I had hit the jack pot when I looked down the list and found line 13
Factory Disarm WHITE/ Dark Green (665 Ohm) left Connector bottom of Fuse Panel problem is, when I dug out the White w/Dark Green tracer and cut it all it did was disable the driver's door lock switch........which is also listed at line 16 as
Door Unlock WHITE/ Dark Green White Connector B58 Connector 250 Ohm Resistor perhaps I have the wrong connector on the left of the fuse panel......but I only see two big connectors, one on the left bottom and one on the right bottom of the fuse panel.
So I butt spliced the wire I cut and the driver's door lock switch works again.
Any ideas on where the Factory Disarm wire actually is and how to use it to disable the alarm system so my wife will use the van again?
Any and all help will be appreciated.
Thanks in advance,
Jim
Posted By: t&t tech
Date Posted: March 01, 2009 at 6:57 PM
the wire you have is correct according to the database on this site, even though the lock wire is the same it most likely is the correct wire it''s multiplex, so you have to connect the wire inline not cut it, connect it with the resistor specified, it normally works with a negative pulse, so it'll be a 665ohm resistor inline on a negative pulse wire, if you have an alarm in the vehicle, aftermarket i mean, connect the factory disarm wire through the resistor, i'm not sure if it's possible to do it without an alarm, maybe someone else can chime in to help out there. | Factory Disarm | WHITE/ Dark Green | (665 Ohm) left Connector bottom of Fuse Panel |
Posted By: jrprich
Date Posted: March 01, 2009 at 7:02 PM
Thanks for the info.
No other alarms. We just want to kill the factory alarm due to the many false alarms it gives.
What is a negative pulse wire? How do I tell if it is a negative pulse ?
Where do I locate a 665ohm resistor ?
Thanks again for your help
Posted By: Mike M2
Date Posted: March 02, 2009 at 7:21 AM
It should disarm every time you turn the key to unlock in the drivers door. When you do this it sends a resisted negative pulse to the BCM for disarm. I've never seen one not work but i guess a bad key switch in the door could make it not work. I think the easiest thing you could do is to tap a 650 resistor onto that wire and run the other end to a momentary switch under the dash and ground the second lead on the switch. This way when it does act up you can simply press the button to disarm it. Go to Radio Shack for the resistor....
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: jrprich
Date Posted: March 02, 2009 at 9:00 AM
When I turn my key in the driver's door the locks do a dance, lock, unlock, lock.....sometimes many times. Do you know if the "key switch" is seperate from the door lock cylinder in the door ?
Posted By: loneranger
Date Posted: March 02, 2009 at 11:37 AM
That sounds like a defective key switch, at the doorlock cylinder.
------------- Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
Posted By: Mike M2
Date Posted: March 02, 2009 at 11:44 AM
jrprich wrote:
Thanks for the info. When I turn my key in the driver's door the locks do a dance, lock, unlock, lock.....sometimes many times. Do you know if the "key switch" is seperate from the door lock cylinder in the door ?
Apparently this is normal and i have no clue why. My work van is a 00 Caravan with the same factory setup and when i turn to unlock it sometimes locks all the other doors at the same time it unlocks the drivers and disarms the alarm. I rarely use it due to having a DEI RS/alarm and i use those remotes which don't arm or disarm the factory stuff but every once in a while i will mistakenly lock the doors with the switch inside when i gat out. This arms the factory and i'll have to turn the key in the door... ------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: jrprich
Date Posted: March 02, 2009 at 12:49 PM
Thanks, I think it is an issue with my BCM.........but I really don't want to spend hundreds or more for a dealer to figure it out or buy a new BCM. Seems to happen to many Gen3 Chryslers/Dodges alarms. I would just like to KILL the factory alarm for good. Thanks again, Jim I think it is a problem with my BCM.....
Posted By: jbauto3
Date Posted: March 09, 2009 at 2:42 PM
Ground the hood pin wire this will stop the factory alarm from arming ------------- jbauto3
Posted By: jrprich
Date Posted: March 09, 2009 at 2:53 PM
Really......just grounding this single sensor will kill the alarm?
I will give this a try.
Thanks,
Jim
