2008 kia sorento
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=112094
Printed Date: March 25, 2026 at 6:15 PM
Topic: 2008 kia sorento
Posted By: kmp1182
Subject: 2008 kia sorento
Date Posted: March 03, 2009 at 10:21 PM
I am going to be getting an '08 Kia Sorento and installing a remote start into it. Does anybody have the wiring diagram on the car?
KP22
Posted By: i am an idiot
Date Posted: March 04, 2009 at 12:38 AM
     Battery          GREEN          (+)          IGNITION SWITCH HARNESS
     Ignition 1          YELLOW          (+)          IGNITION SWITCH HARNESS
     Accessory 1          WHITE          (+)          IGNITION SWITCH HARNESS
     Accessory 2          ORANGE          (+)          IGNITION SWITCH HARNESS
     Starter 1          RED          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          UNIVERSAL IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          YELLOW/ORANGE          (+)          IGNITION SWITCH HARNESSS
     Tachometer          GREEN/ BLACK          (AC)          IN HARNESS TO GAUGES
     Speed Sense          BROWN          (AC)          AT BCM MODULE BEHIND HEATER & A/C CONTROLS
     Parking Lights          RED          (+)          IN HARNESS IN DRIVER KICKPANEL
     Low Crr. Pk Lights          WHITE          (-)          AT VEHICLE LIGHT SWITCH
     Brake Lights          WHITE          (+)          AT SWITCH ABOVE PEDAL
     Reverse Lights          BLUE/BLACK          (+)          IN HARNESS IN DRIVER KICKPANEL TO REAR
     Horn          BLUE/BLACK          (-)          IN HARNESS AT STEERING COLUMN
