compustar cm3000
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=112106
Printed Date: May 09, 2026 at 4:19 PM
Topic: compustar cm3000
Posted By: cristiano
Subject: compustar cm3000
Date Posted: March 04, 2009 at 1:42 PM
where can i find the antenna and the harnesses fr this brain? thank you
Posted By: icarus_icarus
Date Posted: March 06, 2009 at 2:45 AM
I've seen them on eBay from time to time, or contact a dealer...
·Ï¢årµ§·
posted_image
Posted By: Chris Luongo
Date Posted: March 06, 2009 at 8:49 AM
So you have the brain only? Well, you're in luck, because I think Compustar is one of the few brands that actually sells parts separately.
You can buy a wire harness kit, and then you can buy a kit with antenna and remotes.
If you already have the remotes, I think maybe you can buy just the antenna, but I don't know if you'd save much money.
Any local Compustar dealer should be able to order the parts.......prices will vary, and some of them may not want to sell you the parts for you to install it yourself.....so you might want to check a few different places.
