451m, locks not working
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=112605
Printed Date: May 08, 2026 at 5:21 AM
Topic: 451m, locks not working
Posted By: chandlerspeed
Subject: 451m, locks not working
Date Posted: March 23, 2009 at 7:12 PM
Just got done rewiring a 59 Biscayne. Vehicle already had a Viper 350HV installed with a 451M controlling the locks. Everything but locks work after reinstall. Small RED / blue/green harness plugged into alarm, purple has fused keyed power, green and blue going to aftermarket two wire actuators. I did not hook up white or brown because there are no switches. What did I miss? Do white and brown need to be hooked to ground? Also noticed that blue/green on small harness have battery power, is that correct? Thanks in adavance and sorry if a repost, did a lot of research but couldn't find anything.
Posted By: howie ll
Date Posted: March 24, 2009 at 2:37 AM
Purple should be fed permanently, NOT keyed, allow 5-71/2 amps per actuator, white and brown must be grounded, and yes the red on that small harness is also 12v+ .
Date Posted: March 24, 2009 at 10:30 AM
Working great now, thanks. I don't know what I was thinking with keyed power. Amazing what happens when you wire something up correctly.
