remote start problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=112812
Printed Date: April 18, 2026 at 8:30 AM
Topic: remote start problem
Posted By: dwk1204
Subject: remote start problem
Date Posted: March 31, 2009 at 12:00 PM
All of a sudden my remote start will only work if I am sitting in the car (this after I adjusted sensitivity on the shock sensor). Something else that is strange, I can be down the street and pressing the remote button will kill the engine as it is expected to work. I at first thought it was the battery, but both remotes work as explained above.
Thanks in advance..
Posted By: tedmond
Date Posted: March 31, 2009 at 5:48 PM
uplug unit for 30seconds, make sure a connection didnt come loose and then plug back all connections.
Posted By: kim b
Date Posted: March 31, 2009 at 8:26 PM
Mine did that and it was a weak start button on my remote. The stop button is not used as much--Just a thought.Try pushing harder on the start button. ------------- Thanks, Kim
Posted By: shaip99
Date Posted: April 01, 2009 at 1:34 AM
You can try to take the remote apart and clean the board with rubbing alcohol without damaging the circuit I've seen many remotes that get a buildup on the circuit just take a swab and don't push to hard
If it's there it will look like a black gunk for lack of a better work and also clean the back of the soft rubber as well it will be on that to
Hope that helps
------------- "Computer games don't affect kids, I mean if Pac Man affected us as kids, we'd
all run around in a darkened room munching pills and listening to repetitive
music."-Kristian Wilson, Nintendo Inc.
