600 esp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=112882
Printed Date: May 16, 2026 at 1:53 PM
Topic: 600 esp
Posted By: 01burb
Subject: 600 esp
Date Posted: April 03, 2009 at 12:35 AM
I installed a 600 ESP and I have questions.
1) The red LED blinks 1 per second armed or disarmed is this normal?
2) I think the starter interup activated. No matter what I do per the installation manual the car won't start.  It has been in only a couple of weeks and has been working ok until today. Any ideas?
Thank you
Posted By: 01burb
Date Posted: April 03, 2009 at 12:36 AM
It is installed in a 1987 Pontiac Firebird.
Posted By: loneranger
Date Posted: April 03, 2009 at 1:07 AM
  • If it's blinking once per second, the alarm is armed and the starter interupt is active.
  • Put the alarm into valet until you can resolve the issue.
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
Posted By: 01burb
Date Posted: April 03, 2009 at 7:52 AM
Hi I have tried the valet both with remote and button with no results.  I will try again today as it was getting late when I was trying it.  I tried valet mode and VRS.  The alarm is arming and disarming notifing me both with lights and siren.   Any ideas why this is happening.
Posted By: Mark Mizenko
Date Posted: April 03, 2009 at 3:56 PM
The VRS is active?   Do you know how to disarm the VRS.  Is there a seperate button for the VRS, the red port on the module.
Posted By: 01burb
Date Posted: April 03, 2009 at 11:39 PM
I have the manual I printed out.  I will try tomarrow.  No there is not a seperate button unless you are talking the valet button.  I don't remember a red port on the module.  Where would it be?
Date Posted: April 04, 2009 at 12:04 PM
The Red VRS port would be next to the Blue or White ports, IF it had a VRS port.  The VRS may be done thru the remote on your unit if it's newer.
Posted By: 01burb
Date Posted: April 06, 2009 at 10:31 PM
I tried to disarm the VRS per the owners manual with both the remote and valet switch.  The red led still blinks 1 per second armed or disarmed and the car starter still will not engage.  I am open to any ideas.  When I get a chance I will read out the relay, wires and car starter system.
