remote start fails to read tach sig
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=112933
Printed Date: May 16, 2026 at 1:59 AM
Topic: remote start fails to read tach sig
Posted By: hedgehawg41
Subject: remote start fails to read tach sig
Date Posted: April 05, 2009 at 10:11 PM
96 chevy 1ton 4 dr w/valiant rs130 door locks,horn,lights all work programing,hoodpin,all work all wiring double checked 2nd pink/wight ign wired but during tach programing it continues to fail to read signal remote starts but willnot run i,m experienced mechanic but new to electronics this is my truck thanks for any or all advice in advance nubee to site but great source to see peaple helping peaple
Posted By: robertsc
Date Posted: April 06, 2009 at 7:36 AM
Thats the number one reason i only put viper starters in. I have been there more than once its not fun. Last one i did was a ford one for a ford dealership and it was a waste of 5-6 of my life.
Date Posted: April 06, 2009 at 7:46 AM
yeh ,i realized my mistake when i opened the box , wished i would have joined this site first another lesson in you get what you pay for
Posted By: KPierson
Date Posted: April 06, 2009 at 8:04 AM
Where did you get your tach signal from? Have you programmed the tach signal? ------------- Kevin Pierson
Date Posted: April 06, 2009 at 8:15 AM
ive tried both the tach wht wire and the black #1 injector wire truck operates normal w/ key but r/s fails to accept signal
Posted By: KPierson
Date Posted: April 06, 2009 at 8:32 AM
Are you sure it's a tach issue and not a security issue? What happens if you start the car with the key, remote start it while it is running, and then remove the key? Does it die right away or keep running? ------------- Kevin Pierson
Date Posted: April 06, 2009 at 9:03 AM
not sure of security issue i'll try it with the key but when i try to program the tach read 1 flash is accepted 5 flashes failed to read tach signal and it alwayes tells me it failed to readtach
Date Posted: April 06, 2009 at 10:17 AM
hey guys thanks for taking your time to help out just called icdynamics and was told i have abad unit so i think i will send it back with a detailed description of what i think of icdynamics and what they should do with the unit.it'stime to get a quality system thanks again-greit site looking forward to partisipating again in the future
