responder lc, virtual tach, and mt
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113063
Printed Date: May 05, 2026 at 8:58 PM
Topic: responder lc, virtual tach, and mt
Posted By: joebubba
Subject: responder lc, virtual tach, and mt
Date Posted: April 11, 2009 at 3:44 PM
Can anyone explain to me why you can't use Virtual Tach with a manual transmission on the DEI Responder LC models(i.e Viper 5901,etc.)?
Posted By: shaip99
Date Posted: April 12, 2009 at 1:39 PM
you cant use virtual or voltage sense on any manual transmission starter that ive ever worked on plus why would you find a tach line its better
"Computer games don't affect kids, I mean if Pac Man affected us as kids, we'd
all run around in a darkened room munching pills and listening to repetitive
music."-Kristian Wilson, Nintendo Inc.
Posted By: joebubba
Date Posted: April 12, 2009 at 4:03 PM
Uh yeah, I already know that, as I said in my post. But I'm curious as to why you can't use virtual tach with an MT.
Posted By: shaip99
Date Posted: April 13, 2009 at 1:31 PM
its a safety and liability issue
virtual tach and voltage sense do not immediatly go on/off when the vehicle is turned on/off so the car wont know the car is on/off right away
if your battery is low the starter might think the car is off when it is actually running
a tach or alternator sense wire will be an immediate signal so its better  and more consistant
also with voltage sense if the car is on a battery charger it goes to the same voltage as when it would be running
hope this answers your question
Posted By: joebubba
Date Posted: April 13, 2009 at 7:04 PM
So what's that got to do with a manual transmission? DEI recommends using virtual tach for auto transmissions, but the virtual tach can't be used in a manual transmission.
