concept 650 pigtail connections
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113221
Printed Date: May 05, 2026 at 7:52 PM
Topic: concept 650 pigtail connections
Posted By: MM3STB
Subject: concept 650 pigtail connections
Date Posted: April 17, 2009 at 11:09 AM
Hi,
Can anyone tell me which diagram refers to which connector?
Is the diagrams refering to the connector at the car side or the alarm side?
The connectors shown are car side. I cant see any numbers on the connectors.
The alarm is a Clifford Concept 650 mk1
posted_image
posted_image
posted_image
Posted By: howie ll
Date Posted: April 17, 2009 at 5:33 PM
Yes I could but you would need to bench it with a12v supply and a multimeter. When we remove we mark the cables with different colour tapes.
Posted By: howie ll
Date Posted: April 17, 2009 at 5:36 PM
OK I was a bit cruel, look at the left hand  picture, that's the female.
Posted By: MM3STB
Date Posted: April 18, 2009 at 5:38 AM
Thanks,
IS the diagram looking at the wire side of the plug or the connector side of the plug (if that makes any sense) Dont wan't to get this wrong as it would invert the polarity.
Posted By: howie ll
Date Posted: April 18, 2009 at 12:07 PM
Diagramme shows leads from alarm, that's your answer.
Posted By: MM3STB
Date Posted: April 18, 2009 at 4:30 PM
Thanks.
