keyless entry 91 civic
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113235
Printed Date: May 05, 2026 at 9:42 PM
Topic: keyless entry 91 civic
Posted By: that_guy
Subject: keyless entry 91 civic
Date Posted: April 17, 2009 at 8:45 PM
I am trying to install a keyless entry in a 91 civic. I already installed aftermarket actuators and got thos working. I just cant seem to get the keyless system to controll it. Do I need relays. The system is stellar or protocol pppkl3. I just want to use the lock/unlock features (no horn honk, or parking lights). I am not installing any switches to lock/unlock car while inside vehicle. I have installed keyless entry on cars before but they had factory power locks. I have two wire lock actuators.
Posted By: mikvot
Date Posted: April 17, 2009 at 9:00 PM
Posted By: that_guy
Date Posted: April 17, 2009 at 9:16 PM
So I need to purchase some relays? Where can I get them, Napa, Shucks, general auto parts store?
Posted By: mikvot
Date Posted: April 17, 2009 at 9:32 PM
Yes, this is assuming you do not have onboard relays on the unit, which i'm doubting you do. You will need 2 single pull double throw...spdt...relays. You should be able to get them at any automotive parts store, but could order them online alot cheaper.
Posted By: that_guy
Date Posted: April 17, 2009 at 9:39 PM
Posted By: mikvot
Date Posted: April 17, 2009 at 9:46 PM
Funny...i was on ebay at the same time you were....ebay links don't work here, but i was able to match up item numbers. Yes, those will work. You will only need 2 relays total. -------------
Posted By: that_guy
Date Posted: April 17, 2009 at 9:51 PM
If I were to just get another kit with built in relays then the install would be that much easier right. such as this one ebay number 220303435369. That would control the aftermarket lock actuators without any extra parts. Basically a wire in and you are done? Thanks for all of your fast responses.
Posted By: mikvot
Date Posted: April 17, 2009 at 10:02 PM
You could go that route, but the only problem I would have is, how reliable is the system?....which is the problem I have with the system you are using now. You could also just buy the unit itself without the actuators. The ones you have will work fine, considering you've already got them installed. Item # 220243503691 -------------
Posted By: that_guy
Date Posted: April 17, 2009 at 10:09 PM
I saw that but figured the other had free shipping so it almost seemed better to have a couple spare actuators. Do you have any recommendations on another system. I would like to do it once and forget about it. I think I def want the built in relays for ease of install. I live in Alaska and there are not many retail stores so online is my best bet.
Posted By: mikvot
Date Posted: April 17, 2009 at 10:45 PM
I would look at the Valet 712t. Keep in mind, you will not get a factory warranty without it being installed by an authorized dealer.....which is the same with most bigger brands. Where at in Alaska are you? I lived in Adak for 2 years, and spent a little time in Anchorage.
Posted By: that_guy
Date Posted: April 17, 2009 at 11:04 PM
I live in Wasilla so I have to drive an hour to most big stores in Anchorage. Been here since late 05, drove up from Augusta, Georgia. I see that Valet 712t on ebay for around same price as other (260377460219). That will control my 2 wire door lock actuators with no other needed parts?
Posted By: that_guy
Date Posted: May 15, 2009 at 4:42 PM
Got the valet 712t installed and it works great. Thanks for all of your help.
