Light Flash help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11327
Printed Date: April 18, 2026 at 7:47 PM
Topic: Light Flash help
Posted By: DodgeViper754
Subject: Light Flash help
Date Posted: March 23, 2003 at 2:22 PM
       My keyless entry system only has a postive light flash output and my vehicle is the oposite so i cant use those is there a way to hook it up to my back up lights i just want a visual confirmation.
Posted By: djfearny2
Date Posted: March 23, 2003 at 2:31 PM
yea find the wire. anyway if you car is negative and you know that for sure than get a relay and do a polarity change easy convert the positive to negative. take pin 86 and 87 and connect it to ground. and then take pin 85 and connect the positive from keyless entry system. and finally take pin 30 and conect that to the vehicles wire that is defenitely negative . please tell me pesonally by email what make model and year of your car and posibly i can help you further.
Jon
Installer/Help Technician
---coral springs florida---
Posted By: Chris Luongo
Date Posted: March 23, 2003 at 2:33 PM
The section in this site about relays will answer your question... have you looked there yet? Also, no one can help you very well if you don't provide any information---- what kind of car? what kind of keyless entry?
Date Posted: March 23, 2003 at 2:37 PM
I have a 2000 grand caravan and its a executive 3000 by omega
