circuit diagram for honda civic 2006
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113379
Printed Date: April 19, 2026 at 7:02 AM
Topic: circuit diagram for honda civic 2006
Posted By: wolfxinstein
Subject: circuit diagram for honda civic 2006
Date Posted: April 24, 2009 at 5:56 AM
Can someone please help/locate a circuit diagram for Honda Civic 8th Generation( current model)?
been looking everywhere on the internet and couldn't find it.
I'm installing an alarm with a by-pass module.
please help
Posted By: KarTuneMan
Date Posted: April 24, 2009 at 7:36 AM
Use the search button in the right hand corner of the screen!
Posted By: howie ll
Date Posted: April 25, 2009 at 3:12 AM
It has been suggested to me that any one asking this type of question be given a link straight to vehicle wiring.  If they come back with "it shows an 07 and mines an 06" or "it shows a Buick and mine's a Chevy",  we take them out and shoot them...I meant we tell them to use the info as a basis and test from there just like we would. Now to deal with the three similar ones in the wiring requests section.
Date Posted: April 25, 2009 at 3:55 AM
still can't find it. please give me the link.
pleaseeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Posted By: robertsc
Date Posted: April 25, 2009 at 7:41 AM
If you can't find it you should concider getting glasses.
There are two searches on this page.
Posted By: howie ll
Date Posted: April 25, 2009 at 10:36 AM
There are 4 DIFFERENT posts on 06 Civics in VEHICLE WIRING There now 4 queuing up in the vehicle information section LAMS
Date Posted: April 25, 2009 at 11:54 AM
Link........
Posted By: howie ll
Date Posted: April 25, 2009 at 1:08 PM
Need directed 06 Civic wiring posted by someone called Kar Tune Man.
Posted By: loneranger
Date Posted: April 25, 2009 at 4:56 PM
LOL!
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
Posted By: howie ll
Date Posted: April 25, 2009 at 6:34 PM
Suppose I better phone KTM and explain it was an ironic jest but then he knows me, and how I believe sarcasm is just  another sense of humor (goodness gracious, I just gave humour it's US spelling, too many years of hood and trunk instead of bonnet and boot).
Date Posted: April 27, 2009 at 8:12 PM
Thanks KTM for the Link.
But can you please link me a circuit diagram?
Wire/Function Colour Location/Description Polarity
 PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 12 VOLTS White Ignition switch harness   +
 IGNITION Blue Ignition switch harness   +
 ACCESSORY Orange Ignition switch harness   +
 STARTER Yellow Ignition switch harness   +
 KEY SENSE Pink Ignition switch harness in white plug   -
 TACH SIGNAL Opposite from Black and BLACK/ white At any of the coils on the engine   AC
 FUEL INJECTOR Opposite from Yellow/black At any injector on engine   AC
 LOCK Green or Blue In white behind fusebox   -
 UNLOCK Gray In white behind fusebox   -
 DOORPIN SEE NOTES
 Green (Driver's door), Lt.green (pass. Door), Brown (Rear left) and Gray (Rear right). All 4 wires are (-) and found in the green 42-pin plug on the top of the fusebox under the driver's side of the dash.
 HOODPIN Lt.blue At pinswitch or front of fusebox   -
 Not available on all models.
 TRUNK PIN Blue In green 42-pin plug top of fusebox   -
 TRUNK RELEASE Green In green 42-pin plug top of fusebox   +
 FACTORY ARM Pink or Orange In white plug behind fusebox under dash   -
 FACTORY DISARM Brown In white plug behind fusebox under dash   -
 BRAKESWITCH Green In green 42-pin plug top of fusebox or switch   +
 PARKLIGHTS Red In green 42-pin plug top of fusebox   +
 PARKLIGHTS (-) Gray At the light switch harness   -
 HAND BRAKE Lt.blue In white plug on right of st. column   -
 HORN Orange In white plug top of steering column   -
 DRIVER WINDOW UP Red or Yellow At switch in driver's door   Rev Pol
 DRIVER WINDOW DOWN Green At switch in driver's door   Rev Pol
 PASSENGER WINDOW UP Orange In harness from driver's door   Rev Pol
 PASSENGER WINDOW DOWN Brown In harness from driver's door   Rev Pol
 LEFT REAR WINDOW UP Green In harness from driver's door   Rev Pol
 LEFT REAR WINDOW DOWN Violet In harness from driver's door   Rev Pol
 RIGHT REAR WINDOW UP Lt.blue In harness from driver's door   Rev Pol
 RIGHT REAR WINDOW DOWN Red In harness from driver's door   Rev Pol
 HEADLIGHTS Pink At light switch harness   -
 REVERSE LIGHTS Brown In driver's kickpanel   +
 VSS WIRE Blue In plug on back of radio   AC
 TRANSPONDER DATA 1 Lt.Green Pin-3 at 7-Pin connector   DATA
