tach wire 00 impala 3400
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113413
Printed Date: April 19, 2026 at 11:46 AM
Topic: tach wire 00 impala 3400
Posted By: ushank
Subject: tach wire 00 impala 3400
Date Posted: April 26, 2009 at 12:14 AM
I have a 2000 Chevy Impala and it has a3400 v6 in it and I can't find a tach wire.  I have tried every diagram I have access to and it calms to be white at the coil but none of the wires show to be the one.  I have nothing also tried down in the breather box but yet.
Posted By: KarTuneMan
Date Posted: April 26, 2009 at 12:26 AM
How are you "testing" the tach wire? The tach signal IS at the coil pack, and it IS white!
Posted By: ushank
Date Posted: April 26, 2009 at 10:44 AM
witha multi meter in the ac position
Posted By: Velocity Motors
Date Posted: April 26, 2009 at 11:10 AM
What are you installing ?
Posted By: ushank
Date Posted: April 26, 2009 at 11:13 AM
alarm with remote start  I also need to wire a relay for a second ignition could u help me with the diagram
Date Posted: April 26, 2009 at 11:51 AM
At the top of the motor against the firewall ( middle of the vehicle ) that is where you will find the coil pack. There will be 4-5 wires in a 6-7 pin plug. The color of the WHITE may be discolored so strip back some of the split tube looming and tape and this will show the wire colors better. THe plug is right next to the red oil dip stick.
Posted By: ushank
Date Posted: April 26, 2009 at 12:18 PM
thanks. Can you tell me how to wire a relay for a second ignition?
Date Posted: April 26, 2009 at 1:08 PM
Click on Jeffs link in his last post.
It says Second ignition relay
Date Posted: April 26, 2009 at 1:09 PM
Second Ignition relay
Posted By: ushank
Date Posted: April 26, 2009 at 3:33 PM
thanks guys. now I have ran into another problem.  The car starts but dies Iam using a DEI 556 for the by pass I thought the other things I listed were the problem but its not.  I double checked it again and thats what I had. Any i deas?  its some ebay system the customer bought. Its new not used but piece of crap.
Posted By: t&t tech
Date Posted: April 26, 2009 at 3:53 PM
if the car starts then dies, then the bypass isn't the problem, it's more likely a tach issue, if the bypass were the problem the car would not have started.
Posted By: Thack79
Date Posted: April 27, 2009 at 12:07 PM
you have the wrong bypass. its pass II i believe. and I would run tachless on this and forget about the tach wire.
Posted By: ushank
Date Posted: April 27, 2009 at 11:14 PM
I got the right wire and by pass just had to figure out the switches that the manual off the alarm said turn off really had to  be on. Everything working now.  THANKS
