2007 toyota fielder
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113468
Printed Date: May 07, 2026 at 5:37 AM
Topic: 2007 toyota fielder
Posted By: t&t tech
Subject: 2007 toyota fielder
Date Posted: April 28, 2009 at 4:19 PM
has anyone done any of these, it's the new body style, with pushbutton ignition, what bypass would you reccomend, also any ideas on how a second RFID key can be programmed to this vehicle.
Posted By: Velocity Motors
Date Posted: April 28, 2009 at 9:55 PM
It's based on the Corolla platform. You can probably use any bypass that would normally work on a 2009 Corolla for the 07 Fielder with the push button start.
Posted By: t&t tech
Date Posted: April 29, 2009 at 4:41 PM
any thoughts on the rfid tag programming
Date Posted: April 30, 2009 at 7:51 PM
From what I understand, you can't copy this from factory. You will loose it when you don't use the OEM keys.
Posted By: t&t tech
Date Posted: May 18, 2009 at 11:35 AM
ok, i had to dig this post up cuz i didn't wanna restart a new one, the customer says, the bateries in the tag died, and upon replacing them, the pushbutton ignition would no longer respond, so i don't have access to an owner's manual. any suggestions on what can be done, does the system have a failsafe?
Posted By: t&t tech
Date Posted: May 18, 2009 at 6:24 PM
Anyone, there has to be some sort of failsafe procedure, for this situation, i highly doubt toyota would make the system without it, has anyone ever had this problem, i really am counting on the experienced guys here, since locally, there aren't many people who care to learn about the systems, and info is limited, since i don't have alot of experience on these ignition sytems myself, they are fairly new to my market, so any help as to regards what can be done would be highly appreciated, thanks in advance.
