2006 grand caravan keyless entry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113545
Printed Date: April 09, 2026 at 4:39 AM
Topic: 2006 grand caravan keyless entry
Posted By: dbloom3
Subject: 2006 grand caravan keyless entry
Date Posted: May 02, 2009 at 8:30 AM
I want to install an aftermarket keyless entry system in my wife's 2006 Dodge Grand Caravan SE, that we bought used. It has electric locks, but no security system. Just has a regular key with a black rubber head which I don't think is chipped (pic attached). I have had trouble finding the wiring diagram for the '06, but I am guessing it still has a single wire that needs 2k Ohm and 5.2K Ohm resistors for lock/unlock like the '05. Is that correct?
I was also considering using a BCM interface, so I could easily hook up the dome light, horn, etc. I am not sure which model would be correct because most reference the sentry system which we do not have. Would the directed 457CW7 work?
Thanks posted_image
Posted By: iteetwo
Date Posted: May 03, 2009 at 7:34 AM
Constant 12 voltsL BLUE/REDIGNITION SWITCH HARNESS *
  Ignition 12 voltsPINK/WHITEIGNITION SWITCH HARNESS **
  StarterYELLOW (+)IGNITION SWITCH HARNESS
  Dome LightYELLOW/WHT (+)PIN 33 OF 34 PIN CONN. AT B.C.M.
  Trunk PinVIOLET/ORANGE (-)PIN 29 OF 34 PIN CONN.AT THE B.C.M.
  Parking LampWHITE/ BROWN (+)LOWER DRIVER KICK IN REAR BODY HARN.
  LockVIOLET/D GREENAT B.C.M.LOWER LEFT OF STEERING ***
  UnlockSINGLE WIRE SYSTEMCOLUMN IN PIN 21 WHT 34 PIN CONN.#217
* All Wires Are 20 Gage.L BLUE Fused At 10 Amps. For main Power Connection Connect To BROWN / RED Or WHITE/ RED Fused At 20 Amps At 6Pin Conn. At B.C.M. ** Ignition Wire Controls All Accessories. *** Chassis Ground Thru A 5.3k To Lock And Chassis Ground Thru A 2k Ohm Resistor To Unlock. ( Connector Is Third Up From Bottom Of BCM)
#217- See Single Wire Resistor Door Lock Diagram
go to bulldog security and look up vehicle under wiring diagrams they have pictures of the connections hope this helps
Posted By: dbloom3
Date Posted: May 03, 2009 at 4:14 PM
Thanks, that is exactly what I was looking for.
Dave
