new alarm when armed it lock then unlocks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113632
Printed Date: April 06, 2026 at 11:40 PM
Topic: new alarm when armed it lock then unlocks
Posted By: tkeyes
Subject: new alarm when armed it lock then unlocks
Date Posted: May 06, 2009 at 12:13 PM
I just installed an Autopage RS1000 and INT-SL bypass in my 06 trailblazer. Everything is working fine including remote start except for 2 things.
When i arm the autopage, it locks then immediately unlocks the doors?? But the system is armed, light flashes like it should. If i open the door the alarm goes off like it should. When i disarm the autopage I dont not hear the actuators trying to unlock, so it already knows that the doors are unlocked. I programmed the INT-SL correctly. I am using the d2d also.
When i use the factory keyless entry, the doors lock and unlock fine.
Another thing i noticed is that my DRL light no longer are on? And my parking lights are constantley on when the vehichle is running?
Posted By: howie ll
Date Posted: May 06, 2009 at 5:24 PM
You've done something wrong with your wiring. Was there an original factory remote, probably still built into the key. If so try that. If it locks the vehicle correctly then you've made a mistake with your wiring, ditto DRL and parking lights.
Posted By: ckeeler
Date Posted: May 06, 2009 at 5:29 PM
are you testing the locks with the door open?
Posted By: tkeyes
Date Posted: May 06, 2009 at 6:34 PM
Yes the original keyless entry remote works fine. And i tested with the doors close. There is no wiring to the door locks or the headlights, it is all being done through the INT-SL unit with d2d.
I went back and checked all my wiring and meausured every wire and I found out that the brain is also constanly sending 12V on the IGN 1 wire.
I contacted the seller and im returning the brain.. Thanks for the replies guys.
