door locks on 02’ saturn
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113727
Printed Date: April 05, 2026 at 9:04 AM
Topic: door locks on 02’ saturn
Posted By: jdugan4859
Subject: door locks on 02’ saturn
Date Posted: May 10, 2009 at 12:22 PM
I am installing an Autopage RF-315 in a 2002 Saturn SC2. The diagram shows to tag the lt. blue and white wires in the drivers kick panel. I pulled thew kick panel and there is a large connector pack, with several lt. blue wires, and a couple of white wires coming out of it. I am not sure which ones I need to tap, and as far as I can tell, none of them do anything when you lock or unlock the car. The vehicle does have factory keyless entry, and it does still work. Any ideas, I am kinda stumped.
Also, where should I mount the horn on this car, it is tight under the hood.
Posted By: i am an idiot
Date Posted: May 10, 2009 at 12:27 PM
How are you testing the wires?   You are looking for a positive pulse.
Posted By: soundnsecurity
Date Posted: May 10, 2009 at 9:34 PM
you need to be testing with a digital multi meter if you are looking for the lock wires. are you working from a wiring diagram or tech sheet that tells you what polarity the lock wires are supposed to be?
