03 ford explorer, compustar ft 5200s
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113911
Printed Date: May 03, 2026 at 4:35 PM
Topic: 03 ford explorer, compustar ft 5200s
Posted By: jeffwhiteman
Subject: 03 ford explorer, compustar ft 5200s
Date Posted: May 19, 2009 at 3:33 PM
I installed a compustar FT 5200s into an 03 Explorer over the winter. About two months later her truck would not shut off with the key. She said that she started it with the key, not the transmitter. When I looked at it all the connections seemed fine including the brake. I also tried pressing and holding the transmitter(one button)...nothing.
I then removed the brain(the car promptly shut off) returned it for a warranty exchange, replaced it, reprogrammed the blade and sent her on her way. Today, some months later...same problem. Any ideas? Anyone have a similar experience? I cant help but think its a problem with the unit but I have installed many of them and this vehicle is the only one to come back. strange....
Jeff Whiteman
Posted By: Velocity Motors
Date Posted: May 21, 2009 at 10:07 PM
What version are you running on the CM5200 ?
Date Posted: May 22, 2009 at 3:36 PM
I dont have the specific info any longer, the unit is on its way back. I did, however; update it to their latest version back in early Feb. along with the Blade cartridge.
Posted By: batz
Date Posted: January 30, 2010 at 8:21 PM
hey i was wondering i installed the cm5200 on a camry 1995 it woundlnt start it gives me threee blinks and then a 4th blink after 4 seconds so 4 blinks in total but three blinks consisitent. i used the yellow wire under the the engine cover.
