03 trailblazer no start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114072
Printed Date: May 03, 2026 at 6:13 PM
Topic: 03 trailblazer no start
Posted By: chev104275
Subject: 03 trailblazer no start
Date Posted: May 28, 2009 at 8:12 AM
has anyone heard of this i have a 2003 chevy trailblazer wont start with key it doesnt have a remote start in it when i turn the key to the start nothing happens doesnt try to start the dash lights up like it usually would \ checked fuses none blown
Thanks in adavnce Joe
------------- If i Can't Install it I Don't need it Joe
Posted By: Velocity Motors
Date Posted: May 28, 2009 at 8:46 AM
Check the battery to make sure that it's properly charged. Next, check the starter relay or fuse in the engine compartment fuse panel with a DMM. What happened prior to the truck not starting, any information will help us.
------------- Jeff
Date Posted: May 28, 2009 at 10:08 AM
ok fuses are good no symtoms before the problem just wouldnt start last night and again this morn if i play with the ing and tap on the column i can get it to start
Posted By: ckeeler
Date Posted: May 28, 2009 at 11:08 AM
it's most likely a worn out lock cylinder. it's causing the passlock to not work properly, thus you get a no start condition.
Date Posted: May 28, 2009 at 11:21 AM
kinda what i was thinking do i need a scan tool to replace the ing cyl if not how do i code the existing key to the cyl
Posted By: icearrow6
Date Posted: May 28, 2009 at 12:24 PM
bypass module would let you use normal key to start. By normal I meant with out the built in "chip".
The worn out cylinder is the ACTUAL problem though.
Posted By: joch1314
Date Posted: May 28, 2009 at 2:57 PM
Those ignition cylinders seem to be a little more frail than most, especially if you have a lot of keys and/or keychains. the extra weight pulls on the ignition cylinders and causes it to fail....kind of gay if you ask me, but that's GM for you. My sister has a ton of keychains and i'm just waiting for her to have the same problem you are.....already told her about this prob too. ------------- ...half of the truth can be worse than a lie. <----Roger Russell said that..
Date Posted: May 28, 2009 at 3:09 PM
ok thanks guys but do i need a scan tool or a dealer after i install the cyl for any reason ??
Date Posted: May 28, 2009 at 5:05 PM
it was the ing Switch not the cyl
