ford gold alarm/remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114386
Printed Date: April 19, 2026 at 1:20 AM
Topic: ford gold alarm/remote start
Posted By: mmayo
Subject: ford gold alarm/remote start
Date Posted: June 11, 2009 at 9:36 AM
I have a 2008 f350 w/ the Ford Gold alarm/remote start. I think I have the program instructions but cannot seem to enter program mode. I want to change my start time from 30 seconds to 5 seconds. How do I get into program mode??? Thanks -mayo
Posted By: KarTuneMan
Date Posted: June 12, 2009 at 8:05 AM
Why will the dealer not do this for you? This is a dealer installed unit, is it not?
Posted By: mmayo
Date Posted: June 12, 2009 at 8:19 AM
I'd rather do it myself in 10 min than take a full day to have a dealer do something for me........ anyone know how? Thanks
Posted By: chev104275
Date Posted: June 12, 2009 at 3:06 PM
what does the remote look like is it the new gold or the older gold 4 or 6 button remote
------------- If i Can't Install it I Don't need it Joe
Posted By: mmayo
Date Posted: June 15, 2009 at 3:19 PM
6 button
Posted By: i am an idiot
Date Posted: June 15, 2009 at 3:49 PM
This is a manual for the 4 button unit, but the programming instructions may be similar to yours. https://www.the12volt.com/installbay/downloads.asp?srch=all&term=ford+factory
Posted By: skablamm
Date Posted: June 15, 2009 at 10:33 PM
https://techservices.codesystems.com
Create a log in and the programing instructions on there.
Date Posted: June 16, 2009 at 6:25 AM
what are you looking to change ?? if your looking to shorten the diesel timer you cant on these unfortunaly option bank 4 number 5 you can only turn diesel mode on or off
Posted By: mmayo
Date Posted: June 16, 2009 at 7:29 AM
So then I want to turn it off - then it will start in 5 seconds
Date Posted: June 16, 2009 at 11:14 AM
ok turn your key on find the button under the dash and hold it down for about 10 seconds the horn will beep 3 times release the button and press it again it will beep 4 times do this until you get 7 beeps then release the button then using the remote press the red panic button till you get 5 beeps the LED on the dash should be lit use the remotes lock button to turn it off do not hit the unlock on the remote at all it will set all the programming back to default and some if not all of your starter will stop working
Good Luck
