95 civic window module wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11444
Printed Date: April 03, 2026 at 12:52 AM
Topic: 95 civic window module wiring
Posted By: willestl
Subject: 95 civic window module wiring
Date Posted: March 25, 2003 at 3:37 PM
i need help with wiring a window roll up module for a 95 honda civic. i check the wiring diagram at this site and it said for windows up- LF=RED / blue, RF= blue / YELLOW and for windows down- LF=RED / yellow, RF= blue/green. but i don't know what the wire is for the left and right motor wire. i bought my window roll up module at www.hpdistributinginc.com. all i want to do is have two of my windows to roll up when i arm my car. this is the wiring diagram it provides me.
pink- to accessory item
green- left motor
white- left switch
orange- 500ma. activation
black- ground
red- +12 volts
blue- right motor
brown= right switch
what is the pink wire for anyways?
any suggestion would help
Posted By: willestl
Date Posted: March 25, 2003 at 3:38 PM
one more thing.... do i need a relay for this project?
Posted By: Velocity Motors
Date Posted: March 27, 2003 at 8:27 AM
|  LF WINDOW UP/DN|RED / yellow - RED / blu|A  |drivers door                |
|  RF WINDOW UP/DN|blue/yel - blue/grn |A  |drivers kick panel
The above colors is what I have for the 1995 Honda Civic. Check with a DMM for proper wires while toggling the switch to activate the windows. You will not need a relay but you will need to hook up the starter disable wire to the ORANGE activation wire on the module. When you are the system, the windows will automatically roll up. The Pink wire to my knowledge is a (-) output to any ACC item, but correct me if I'm wrong. I have heard that this connects to a IGN source but I have never done so in any of the units that I have installed.
