toyota bb
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114620
Printed Date: April 02, 2026 at 6:23 AM
Topic: toyota bb
Posted By: troublestarter
Subject: toyota bb
Date Posted: June 22, 2009 at 9:47 AM
need a wiring diagram for the above mentioned vehicle it is an import cheers ken
Posted By: i am an idiot
Date Posted: June 22, 2009 at 10:33 AM
It appears to be a Scion Xb. Do you have any idea on a manufacture year?
------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: howie ll
Date Posted: June 22, 2009 at 4:00 PM
With one exception, nearly all Toyotas are identical on the wiring, indicators will be GREEN/ black and GREEN/ YELLOW, locks will be neg triggered and at a plug where the cables from the driver's door enter the car, in the DKP, door contacts will be RED / white with silver dots OR coming off the fusebox, 3 way plug or at the dome light, if there is a delay it will shut down immediately the locks are triggered, the only exception being late Toyotas (07 on) use diffferent ign and start colours. I did Cat 1 alarms on an 03 and an 08 Yaris last week, each took me 2 hours, (never done one before) when the expected time is 6. They are the easiest cars to do. I say that having just down a Cat 1 with intellistart and tracking and total close on an Audi RS4. Give me the Toyota any time.
Posted By: t&t tech
Date Posted: June 22, 2009 at 5:14 PM
Six hours howie, . How"ve you been ?
Posted By: howie ll
Date Posted: June 22, 2009 at 6:11 PM
OK apart from the Audi, amazingly enough, the RS worked without the 556U being connected! Strange. I think paradise would be lots of 30 year olds (remember I'm 63 in September) the South of France, working Toyotas and the best food from around the World. 6hrs = 2 x immob cuts, the awful (mountings) DEI batt back-up Siren, mandatory hood and trunk, firmly mounted, either bolted or cable tied and stealth wiring. Don't forget I'd never done either Yaris before and had to test everything. I've sent you, KTM and Mr. Idiot the ultimate Jewish Joke on your personal emails.
Posted By: KarTuneMan
Date Posted: June 22, 2009 at 8:35 PM
I too, come from a wonderful family Howie.... !!!
